GL steering wheel sensor
Old Oct 4, 2017 | 10:40 AM
strok's Avatar
GL350 2013, Sprinter 2016
Hi guys, I need your help with understanding the steering wheel sensor operation.
Some of the errors I'm getting suggesting a faulty steering wheel sensor.
No active alarms regarding the steering wheel sensor.
But I have one stored alarm (defective steering wheel sensor).
The Star seems to be reading the angle.
Is it possible to have a defective sensor even if it has a reading?
Thanks.
Old Jun 15, 2021 | 02:44 PM
rich30769's Avatar
2009 GL550 ; 2005 Lexus LS430
Thanks.
Just received the "ESP Inoperative" message myself. Any resolution to this? About to put the computer on it later today.
Old Jun 16, 2021 | 01:13 PM
Misha_'s Avatar
2012 GL350, 2014 GLK250
I do not have any errors but am curious about this. In the build info my GL has a steering wheel vital sensor, but I have not seen any manifestation of it, and never found any info on what it is/does.
Old Jun 19, 2021 | 01:38 PM
eric_in_sd's Avatar
2007 GL450
There are various threads here on the ESP Inoperative error messages, and techniques for rectifying. It is an optical sensor and apparently the sensor benefits from being cleaned. It's not a difficult job if you are patient and methodical. Otherwise, simply replace the sensor, which is not very expensive.
Old Jun 28, 2022 | 03:27 PM
Antonio s600's Avatar
W221 s550
​​​​​​Where is the optical sensor located at?
Old Jun 28, 2022 | 04:11 PM
eric_in_sd's Avatar
2007 GL450
It is in the steering column, right under the steering wheel.
Old Jun 29, 2022 | 08:49 AM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
try a steering angle sensor reset.
turn the car on
move the wheel all the way left and all the way right. many times this will reset the system.
can also be performed with a scan tool
