Help!
Help!
My GL320 is poorly. The engine warning light is on and the engine has low power. When idle, the engine can be revved over 3000 but the turbo has a terrible shuddering sound. Seems better when the intercooler hoses are off.
The mechanic isn't sure what the issue is but he suspects either a blocked intercooler or a blocked DPF (though none of the codes mention the DPF). Any help would be appreciated as they are expensive parts to speculatively change!
Engine codes are:
2526-4 Charge pressure positioner. Signal line is interrupted
2527-2 Left EGR positioner. Short cct to ground
3053-4 Intake air temperature sensor. Signal Fault. (B2-7b1)
3052-4 Intake air temperature sensor. Signal Fault. (B2-6b1)
2627-4 Mass airflow sensor is faulty
2603-2 Right hot film mass airflow sensor. Air mass is too small
2602-2 Left hot film mass airflow sensor. Air mass is too small
Engine codes are:
Engine codes are:
Engine codes are:
