Keyless Go Module failed
Old Jan 6, 2018 | 12:22 AM
Tdog1's Avatar
2012 GL550, 2006 CLK350, 1999 Porsche 911
2012 GL550. 60k miles. Suddenly, all the Keyless Go functions stopped working... no push-to-start, no unlocking by touching the handles. Took it to dealer and they advised Keyless Go module needs to be replaced for $900, part and labor. Ouch! So I paid them their $150 diagnostic fee and took the car without fixing it. I could buy the part alone for $580 and replace it myself but honestly, the features if Keyless Go aren't worth that kind of money, imho. The key fobs work normally, btw.
Anybody else have this issue?
Any ideas where i can buy a used Keyless Go module? I'd fix it if it were only a few hundred bucks. I've looked online and have seen some on ebay but the part numbers don't match what the parts department said I needed, and I don't want to spend money experimenting with a non-exact matching used part.
Old Jan 6, 2018 | 11:15 PM
Tdog1's Avatar
Originally Posted by Plutoe
Look again within EPC you may have been quoted a current part when older parts work just as well and they may be the ones on flee bay
Thanks but what is EPC?
Old Feb 27, 2020 | 05:08 PM
Freddy Camacho's Avatar
2011 GL450
Hi guys,
I am having the same problem here and after all the diagnostics, I came to same conclusion that the Keyless module is bad. I have found some on eBay that may work according to compatibility chart. My question is if I get a this replacement or new one, is there a procedure to reprogram the module or pair the FOB again? Any assistance will be greatly appreciated.
I have a 2011-GL450 X164
Old Mar 1, 2020 | 03:30 PM
Yup497's Avatar
2010 GL550 | 2020 S560
FYIW- Have any of you changed your battery or had your GL's battery checked? Strange things happen when the batteries are going bad. I'd at the very least get the battery checked (most places do it for free) before you start making big purchases.
Old Jun 14, 2020 | 05:35 PM
Brtiii's Avatar
R230
Try the fuse
Temporarily remove the fuse for the KG then replace.. also check to see that it did not get wet
if you replace the module you will need a new key from MB to program, the old ones will still function to start car
Old Mar 22, 2021 | 09:56 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
Originally Posted by Freddy Camacho
Hi guys,
No Need to Reprogram any keys, the module is just a wireless transmitter, if keys work in the switch its will work keyless go thats if you have a keyless go FOB
