First Mercedes - GL320
I just got my first Mercedes, a 2007 Mercedes GL320 with ~160K miles on it. Beautiful vehicle and quite an upgrade from my 2000 Honda CR-V. A few questions, I tend to do most maintenance myself when possible with the most involved probably being a timing belt, but I am noticing the Mercedes seems to have quite a bit more complex system with the STAR 4 system and such. I am thinking maybe buying that off eBay will make sense at some point but prefer to avoid as long as possible. The Mercedes checked out pretty well there were a few issues I need to resolve and I'm guessing most won't require any computer changes, but let me know if not.
Also, if you have suggestions on best place to confirm part numbers/schematics, recommended part suppliers, torque specs, etc. Here are the issues the inspection found.
-Rear Shocks - they said the compressor and bags were ok, so I'm hoping this is just like a normal shock/strut change. After the shocks on Amazon usable or should I be special ordering these?
-Transmission Cooler Lines - I'll probably have a mechanic do this one
-Muffler Hanger - just need to figure out how to find the part
-Transmission Mount - same
-Power steering rack seal and hose rings - not sure how invasive this one is yet, if it's reasonably accessible I'll probably take this on
-3rd Row Seat Belts - again just need to figure out best way to confirm parts
-Battery install - does this require any computer changes? In any other car I just swap it out and it works, but let me know if this causes radio lock outs or anything else
-Netting behind front seats - Looks like this requires taking off the seat back and replacing it or hacking it a little bit with new netting and bungies
Anything you can share that would be helpful would be most appreciated.
The Gl320 is a great vehicle, Enjoy!
Then buy parts from mbdirectparts.com
On Mercedes, one replaces one shock at a time.
After battery replacement, you have to normalize the windows and sunroof, calibrate the compass, and reset the clock. Before disconnecting, switch off everything electrical you can and if there is keyless go, get the key away from the vehicle.
Also, any good source that lists the torque settings for the vehicle?
