Gl driving hard
I had this replaced a couple weeks ago and it made an extreme difference from riding hard to plush.
Mine was at 80k and 8 years.
Nothing rides as smooth as the air suspension in full working order.
For me, I couldn't tell the difference that there was a issue with the leveling rods except for that the ride had turned harsh.
The height and level seemed the same and appearance wise the car looked the same height it always had been.
But once the leveling rods were replaced, and I jacked up the suspension using the raise function I could definitely tell there was more lift than before. Considerably more.
And all was plush and soft and cushy once again.
Although having winter Tires help. 😬
I personally did not. It was taken care of courtesy of my extended warranty, which also replaced a belt tensioner and the center idler pulley at the same service too.
I've attached my receipt if it helps.
I think someone will tell you that the airmatic suspension will need to be reset...... But driving around should help it sort it's proper level no?
I climbed under the car before it got dark, my fronts are definitely....at risk of breaking but still function. The reears are definitely new.
Truck needs to be calibrated with star/ das. Older trucks get their dog bones frozen which results in changes in ride height and stiffer ride.
Dan
