slow cranking
slow cranking
2 kind of problem with my GL500 2012
1- after 15-minute driving, turn of and on the cranking slowdown.
2-the ignition takes the time or delays more than expected
while the vehicle is cool there's no problem in both matters.
please advice me.
please advice me.
My 08 GL550 is doing the same for about 2 years. Changed the crank position sensor but it did not help. It is more of annoyance as it does start after long crank. Cold cranks are good.
https://mbworld.org/forums/gl-class-...g-problem.html I'm told the solution may be in this thread. A damaged cable. Part # 164-440-07-36
Got the same problem that worries me as weather gets colder.
I'm about to order the positive cable but want to be 100% sure before doing that..
Please write below that other topic which is essentially the same thing.
Its a cable harness replacement.
