Airmatic compressor doesn't work
Old May 1, 2018 | 06:38 PM
megaplex's Avatar
Unhappy Airmatic compressor doesn't work
Fuse , Relay,airmatic compressor control module is good but the compressor still will not turn on, any ideas what the problem could be?
Old May 1, 2018 | 08:08 PM
alx's Avatar
alx
compressor motors rarely fail. it is usually the piston or the reservoir that fail, but motor would still turn.
if you dont have star/ das to actuate motor to confirm you can unplug connector and measure for presence of 12v dc. make sure doors are closed as compressor would not run with doors open.
Old May 1, 2018 | 11:13 PM
megaplex's Avatar
Thanks for the reply all, but I figure it out. I was the compressor connector. I guess the pins in the connector was not making contact. I fix it and now the compressor is working now.
