keyless go problem
Old Jun 13, 2018 | 04:25 PM
Alpacadan's Avatar
2010 GL350
keyless go problem
2010 GL350 bluetec keyless go works perfectly on both doors on passenger side, but does not work on either door on drivers side. Fob will unlock doors when pushing the unlock button, but doors will not unlock when I approach the door and they will not lock or unlock when I push the button on the handle. Wondered if it could be a fuse problem, since both doors on drivers' side effected.
Old Jun 19, 2018 | 05:28 PM
Isentropic's Avatar
2001 ML320 (gave to family member), 2007 GL450
I would recommend replacing the fuse in the trunk, which worked for me.
Old Dec 16, 2020 | 10:34 PM
ltpace610's Avatar
2012 GL450
Hello,
Was this issue that you were having apply to both handles (front and rear) on the driver's side of the truck? If so were you able to resolve the issue? Also which fuse did you replace and was it blown or you just replace it?
