Wheel lug help!😬
Old Jun 14, 2018 | 08:04 PM
ramie's Avatar
07 C230 Sport
Wheel lug help!😬
I took off my wheel lugs to sand and paint them. My question is how long should they be?
Old Jun 15, 2018 | 11:08 AM
sak335's Avatar
2012 GL 350
The shank (i.e. threaded part) should be 45mm with a ball radius seat.
Old Jun 15, 2018 | 11:14 AM
lkchris's Avatar
'10 CL550, '12 GL550
Same size as the X166 chrome plated multi pointed bolts which are way cooler than anything you can do to your original 164 bolts.
the shorter bolts are for spare tire only
Old Jun 18, 2018 | 02:50 AM
sclasspilot's Avatar
2008 ML320 CDI with every option code including Offroad pack, 1978 450SEL
Bolt shank length is actually dependent on the alloy wheel model.
In my case, the 19" diameter factory rims require a longer shank than the 17" factory rims (my offroad set), so I have two separate sets of bolts.
Haven't got the bolts in front of me, but I recall the 17" wheels require a 27mm shank.
Be careful if swapping around. If you use longer bolts where shorter ones are needed, it will poke through into the wheel hub and destroy your handbrake mechanism as soon as you move the car.
Old Jun 18, 2018 | 11:17 PM
lkchris's Avatar
There are no 17-inch wheels for GL ... perhaps you’re thinking of ML.
Also pretty sure the same lug bolts are used with most if not all X164 alloys. Different bolts for the steel donut spare wheel of course.
Old Jun 19, 2018 | 12:15 AM
Yes, I was thinking of ML!
I have an ML but haunt both the GL and ML forums, and forgot which one I was on.
However for the ML, I can confirm the bolts used for both the 17" alloy wheels and the steel spare wheel are exactly the same.
