ISM Fault
Old Jun 29, 2018 | 03:32 PM
WinterPark321's Avatar
2009 E550, 2011 GL550, 2013 GL550
ISM Fault
Hi.
Was driving my GL550 2011 on the interstate the other day and suddenly when pressing the accelerator, the car would not change gears and also rev at high rpms without shifting. Recently, both front and rear speed sensors were replaced with genuine parts. No check engine light came on. Afterwards, car was scanned and came up with code 1709: "The actuator motor in the component A80 ISM (Intelligent Servo Module) for Direct Select cannot reach its specified target position."
Has anyone had this problem? Is the ISM faulty or the Valve body/conductor plate? Where is the ISM located and how much does the stealership cost to change it?
Tek
Old Jun 29, 2018 | 07:36 PM
Originally Posted by Plutoe
Post your VIN!
VIN is 4JGBF8GE8BA645852
Old Jul 7, 2018 | 01:36 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
The ISM is bolted to the driver's side of the transmission case. I don't think this codes is what's causing your transmission to stay in one gear. What are you scanning with? You need to scan with Xentry/DAS.
Old Jul 7, 2018 | 05:13 AM
Hi I am currently scanning with Aurelius Maximus and have the code 1709.
Old Feb 1, 2023 | 05:00 AM
EmilyMB's Avatar
gl550
Originally Posted by WinterPark321
Hi.
Tek
i have the same code 1709 and c103.
please update your solution. Thank you
Old Feb 1, 2023 | 05:25 AM
Max Blast's Avatar
NGL450 w/EORP, S550
The usual valve body/conductor plate failure mode is a red “drive to workshop” warning and then the transmission locks in 2nd gear.
That is if you slow down enough for it to do that - if you stay at highway speed I do believe it holds highway gear until you slow down but will not upshift again.
Old Feb 1, 2023 | 09:54 AM
EmilyMB's Avatar
gl550
Thank you for your inputs.
Mine is running at low/high speed great. Only problem when weather is cold, dashboard lights go off and red msg drive to workshop …
tried to test ISM actuation test and red “drive to workshop….” Popped right ip on dashboard…
still searching and tracing for stray current, modules. …
