Shameless plug for Arnott
Pro tip: Leaks develop at the fold, so if you lift the suspension, the fold area will be exposed. Squirt soapy water all over the bag and look for a spot of fine foam, like stoner spit.
Found a spot of foam on both rear bags and one of the front. Curiously, this was one that I'd replaced just a few years ago, under warranty.
Left Arnott an online message. It was well past their closing time. The next morning, got a call back; she said their policy is to not call residences before 8:30 local time. After discussing the history, she said the original front unit I'd installed was an older design, and so I now have four new units headed my way.
This is how you do customer service. This is why I didn't hesitate to order a compressor from them, as well, as mine is original and becoming noisy.
I had a clanking noise appear days after installing a replacement strut, and they were kind enough to send me another one - and then followed up to politely inform me that there was nothing wrong with the strut they'd received back and I had better start looking around. They could cost twice what the MB product does and I'd still go with Arnott; as finicky as these air springs are, you'll want the support.
I needed a new compressor, and didn't think twice about getting the Arnott product, even though it was more expensive than alternatives, because I wanted to know I'm getting a product the company stands behind (unlike cough Mercedes cough).
In reality they describe premature failures and quality problems with this company’s products.
Bilstein items are available at same or lower prices and are identical to Mercedes-branded items, as they are the OE manufacturer. You know, the items that lasted (in my case) 11 years without problem.
If you have discovered some secret sauce to make the bags last 11 years, you're criminal for not sharing it. In particular, I think Arnott would be excited to hear about it.
If this joker has gotten 11 years out of a set, then I would have to assume he put the truck up on jack stands and released the pressure. In my own case, it's not environment; my GL is driven in mild California weather and garaged when not driven. It is also possible that the tiny leaks I found would have not grown in any short amount of time, so they technically shouldn't have been counted as failure. It speaks volumes that Arnott was accommodating; I know M-B wouldn't have been, and I suspect Bilstein would not either.
