ESP Inoperative - Steering Angle
Old Aug 7, 2018 | 11:37 AM
eric_in_sd's Avatar
2007 GL450
A while back I had an ESP error. Cleared it with the lock-to-lock thing.
A more persistent error about two weeks later. This time it wouldn't clear. I tried cleaning the Steering Angle Sensor, but no luck. I still have the error. Details: 5170* Steering wheel angle Zero point variation. The sensor reads -16 degrees when wheel is pointed straight ahead.
The info I've seen on SAS failure indicates that it yields massive errors, i.e. 720 degrees. I ordered a replacement SAS, but if anyone has any ideas about other stuff to try, let me know.
*MBII reports as 5170, though I've seen lots of people refer to it as C1170.
Old Mar 18, 2021 | 12:28 AM
qman56's Avatar
SLK-350, R-350
I have this issue now. did you ever get a permanent solution?
Old Mar 18, 2021 | 06:14 AM
eric_in_sd's Avatar
2007 GL450
I cleaned the SAS carefully, reassembled, and redid the calibration. No issues since.
