icarsoft Question
Old Sep 27, 2018 | 07:55 PM
audioneurotica's Avatar
2008 GL 320 CDI
icarsoft Question
Purchased an icarsoft MBII specifically because it was supposed to be able to get into the ABS system. So far I have not been able to get into the ABS. My emails to customer service have so far been ignored. Anybody out there have any suggestions ? I'm not looking forward to testing each sensor separately. Thanks, Will
Old Sep 27, 2018 | 10:16 PM
smagna00's Avatar
GL320
I bought an Icarsoft CR Plus over the weekend, and was just checking my '07 GL320 not 45min ago. Timing is everything
I was having some ABS faults and found all the codes i seeked under the ESP (electronic stability program) test menu. I have a bunch of bad or out of position wheel speed sensors.
Not sure what you are looking for, but maybe try under that menu. BTW i also had to reset my EBV ABS and ESP because i was getting an "Inoperable. Diagnose" warning on the cluster. Didn't need the icarsoft for that. Just googled the procedure, and reset the system. Good as new. No dash bangs anymore. Let me know if you need the step by step proceedure
Sam
