Cyl 5 6 7 8 misfire
Cyl 5 6 7 8 misfire
just replaced all four cam magnets to solve p0012 p0015 and p0025 code. Started her back up now Im popping codes for cylinder misfires. Change the spark plugs now? Any help is appreciated!
I assume there were no misfire codes before changing magnets.
check connectors on magnets to see if they are properly connected. (or are not cross connected)
could you try to put the old magnets back to see if cylinder misfire codes go away?
if there were no misfire codes before, and if we assume that new magnets are good ones, the timing is being off somehow.
Correct, no misfire codes before I put in the new ones.
double check all the connections and they are good.
anyway to reset the timing using the icarsoft mb II scanner?
thx
thx
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,983 Likes
2017 GLE350 4MATIC
