Comand NTG2 - DVD Format ?
Old Dec 1, 2018 | 12:00 PM
-CaLViN-'s Avatar
X164 2007 GL 450 4MATIC
Hello fellows,
I am trying to play some DVDs with animations inside for kids but i havent been succesful yet.
It is playing purchased DVDs but my own written ones doesnt work.
I have used Data format while writing disks,am i doing something wrong ? I havent tried DVD format btw.
I just want to make sure before writing another disk.Could you please advise me on this ?
Thank you!
Old Dec 1, 2018 | 03:07 PM
JesusV's Avatar
2012 GL550, 2016 C300, 2005 Mustang
The Command manual says some copied discs my not play. I suggest trying to copy it as a DVD format. It can play mp3s from a dvd too. For movies, make sure it's copied as PAL or NTCS and region 1.
Old Dec 9, 2018 | 10:47 AM
-CaLViN-'s Avatar
Well,
Seems like this will be too much trouble.
How can i play movies on rear screen ? Is the only way aux ? What kind of device do you recommend for aux input ?
Something like ipod ?
Old Dec 9, 2018 | 01:22 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Originally Posted by -CaLViN-
Well,
you can't use the data format to burn the cd's or dvds. You have to use the native dvd format.
You can buy a hdmi to composite adaptor and connect a fire TV stick with your phone as a hotspot.
It worked for me and I was able to Netflix plex and prime and live TV using direct tv now.
iSimple ISHD01 MediaLinx HDMI To Composite Video/Audio Adapter Cable (Black) https://www.amazon.com/dp/B00LUX1F5K/ref=cm_sw_r_cp_api_i_x3vdCb30SD71Z
It worked but then it fell apart so....but it works.
Old Dec 9, 2018 | 01:26 PM
kombifan's Avatar
Someone on here built a plex server with a raspberry pi connected to a hard drive ...and connected it via the composite.
But that's a project.
Old Dec 9, 2018 | 02:41 PM
-CaLViN-'s Avatar
Well,
That connection via a mobile phone seems logical but i need a permanent solution like putting all videos in it and playing for kids.
Old Dec 9, 2018 | 03:47 PM
JesusV's Avatar
The picture quality won't be the best, but the easiest way would be to play off of the iPod through the aux input.
