Ml350 Headlight
Old Jan 11, 2019 | 01:10 PM
justustm2's Avatar
2008 ML350
Ml350 Headlight
Does a 2007 ML450 Bi-Xenon headlight assembly fir a 2008 ML350?
Old Jan 11, 2019 | 03:07 PM
DennisG01's Avatar
'08 GL 320 CDI
Probably best to ask in the ML forum - this is the GL. But as long as there were no major design changes, it should. Compare pictures - easy enough to find on the net.
Old Jan 11, 2019 | 07:45 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
If the 2008 didn't come with bi-xenons, there will be some wiring involved and I'd guess you'll probably get a "Headlight out" warning unless somebody sells a device to make the monitoring system see the right impedence (or whatever it uses to test for burned out bulbs).
Old Jan 11, 2019 | 09:20 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
compare mb part numbers!!!!
mbwholesalepartsonline.com
Old Jan 12, 2019 | 04:06 AM
justustm2's Avatar
2008 ML350
I dont have part numbers!!!.
Old Jan 12, 2019 | 08:31 AM
kombifan's Avatar
compare the part numbers of what you have to what you want to buy.
https://www.mbwholesalepartsonline.c...omponents-scat
yiu posted originally in the ml forum saying you had xenon headlights. Stick to posting there as you’ll receive more detailed advice.
Look at the part numbers on your car. Compare it to the website i sent you. Compare the part numbers to the ml450 headlight you found.
