Climate Blower Motor Turns On After Car is Shut Off
The real question is how did all of that moisture build up inside the coated, sealed resistor cover so I can prevent reoccurrence?
Its a design issue. The vent in the hood allows rain/snow/water in and the blower sucks it in and throws it into the board. If you open the housing on the fire wall (just 2 clips- easy)
you can see the path via the hole on the bottom.
Mine is a 2008 - 14 years old. Cleaning the contacts every 14 years isn't bad, I'll live with it. Or, you could put a sponge in the hole to absorb any water...LOL
BTW: I think the fuse for the blower is next to the battery...another stroke of genius...
Many thanks to all who share their experiences here.
thanks to this thread, i was able to diagnose and solve this very weird problem. i HATE electrical issues on cars, as they can be a nightmare to trace down.
as other users have pointed out, what ends up happening is that water from carwashes/rain/snow/etc will fall into the hood vent and drip down into the drain channel. most of it will drain as needed, but some water may get by (esp if the drain becomes plugged) and will seep into the blower motor where it will rust out the main center bearing and drip down through it and get into the bottom where the circuit board is, and short it all out- causing the fan to have a mind of its own.
i have attached a pic of my stock blower and the replacement from ebay, you can see the design revisions as well as the rusted out center bearing on the old fan on the left. especially of note, notice how the old blower on the left has HUGE openings that can easily allow water into the core of the motor. the new one is sealed up tight like an umbrella. i suspect this will be a much better design.
the new part was 100 bucks on ebay, and appears to be a revised version of the stock Siemens blower that came on the car. i suspect this revised blower motor may not have this annoying issue, but i will report back if anything comes up in the future.
the fix was not too bad, the hardest part was unplugging the old fan plugs (2 of them) in february with cold fingers on a garage floor. one plug has two clips on each side, the other one may require a small screwdriver to help you move the clip on the side. but once you get the old fan out (4 torx bolts) after dropping the panel below the glovebox (also 4 torx - same as the fan) the old unit comes right out and the new one fits perfectly - and thanks to MB desiging a pro socket, you dont need to worry about bolt alignment as they all self-locate making it much easier to work since the repair is done all by feel rather than by vision.
tested the new blower motor these last 2 weeks, in all AC and HEAT modes, AUTO and MANUAL, and everything works great. PLUS the new blower has an audible "power down" about 1-2 seconds after you shut the car off, meaning its very obvious that you HEAR a power down (and thankfully never a power UP
meaning i no longer have to worry about something running all night when i dont want it to and waking up with a car that wont start. just want to thank everyone in this wonderful thread for the great information and wisdom on the root cause of this weird electrical issue. i wanted to add my experience as well, in the event it can help some future w164 owners. this is also a great time to change out both cabin air filters as well!
huge shoutout as well to @srtdc for their knowledge and wisdom on the underlying cause!
I think you are looking at this that it turns on/off the 12 volts...The 12 volts is always present. The blower is not shorting, there is no relay, the b,lower is inadvertently turned on by the PCB.
The PCB is not a "resistor". Its a data (CAN BUS) receiver that turns the blower on/off, controls the speed, etc.
Everything is fine now. So if youre experiencing the same symptoms open up the blower motor and check out the resistor. Unlike the Audi/VW where the resistor is separate, in the GL its built in/ part of the motor.
If you need instructions on how to get to it I can take some pictures but its fairly easy to do.
the blower continued to blow from the third row seats while I had the blower motor removed suggesting that the problem lies elsewhere. Unsurprisingly, after refitting the problem remains as before.
any suggestions please?
If you run your air conditioner, before you shut the engine down, put environmental control to vent, and let it run for a couple of minutes.
It will cause more wear and tear on motor, compressor and accessory belt if you shutdown engine with air conditioning on, and or start the engine with it on.
The reason for switching to vent is for the reasons previously mentioned in the thread.
Running the vent helps to remove moisture and the problems moisture causes.
It is possible the board is shorted thru the power FETS also. If you are good with a multi meter you can follow the power trace and see if it is shorted thru the turn on device.
meaning i no longer have to worry about something running all night when i dont want it to and waking up with a car that wont start.just want to thank everyone in this wonderful thread for the great information and wisdom on the root cause of this weird electrical issue. i wanted to add my experience as well, in the event it can help some future w164 owners. this is also a great time to change out both cabin air filters as well!
I just repaired a major oil leak myself on my wife's 2012 ML350 Bluetec (also bought new in 2011). A leak from the filter housing and timing cover caused a virtual explosion of oil in the engine bay and caused the shredding of the serpentine belt like Big League Chewing gum. It was all in the crank, AC, alternator, water pump pulleys. It was a mess. .............it's neither here nor there, but thank you for posting your results. Much appreciated!!
