Upstream oxy sensor early life failure?!?
Old Mar 3, 2019 | 03:39 PM
eric_in_sd's Avatar
2007 GL450
I changed the bank 1 sensor 1 about 6k miles ago. At 4K miles, saw a P0133 error: Slow response. Now I got P0135, heater malfunction.
Here's the question, fam: What are the odds this is something besides the core of the sensor itself? Like the plug connector, some jive on the ECU?
Old Mar 3, 2019 | 06:34 PM
eric_in_sd's Avatar
2007 GL450
hahaha took me a few minutes
that's mighty small odds
thanks fam
Old Mar 3, 2019 | 07:12 PM
alx's Avatar
alx
didi you buy an oem sensor? those need to be oem... or you will suffer
Old Mar 3, 2019 | 09:00 PM
eric_in_sd's Avatar
2007 GL450
Bosch. They make the MB part, no?
The errors are non recurring, which made me suspect wiring in the first place.
Old Mar 4, 2019 | 08:27 AM
eric_in_sd's Avatar
2007 GL450
In fairness, the decimal point lacked a zero to its left and went unnoticed. I assumed you were the one PWD (Posting While Drunk).
Old Mar 4, 2019 | 08:36 AM
eric_in_sd's Avatar
2007 GL450
I took a look at pending codes: P0174, P0133, P0153.
153 is the bank 2 upstream slow to respond. The same error, both sides. Coincidence or ECU or MAF sensor (?).
It's along with the 174 error (too lean). I'd had this error before; it didn't recur after cleaning the sensor, but now it's back. Seems to suggest it's the sensor.
I'll swap the sensor (I have a spare on the shelf) and post back.
Old Mar 14, 2019 | 08:42 PM
eric_in_sd's Avatar
2007 GL450
Update: I swapped the sensor and, while I was in there, removed and gave some lovin to the big elbow the sensor sits in. The seal and strength of connection to the throttle body / intake manifold was kinda flimsy and loose. I doubt it was leaking significant air, but it may be that oil leaking down from it (that's where the PCV hose connects) is responsible for the residual oil burn smell after I replaced the cam housing plugs.
If you get in there, I'd take some time to clean it all up and make sure that elbow is seated correctly. It's a disturbingly flimsy attachment, and muscling the air cleaner housing on seems likely to dislodge it. I also lubricated all the rubber parts with silicone grease to make them fit together more easily.
Anyway, bottom line on the MAF sensor change: It's been a few miles and no recurrence of the oxy sensor errors. I'll post back if they recur.
The MAF sensor might be a good place to start if you get funny fuel system errors. It's cheap and easy to replace.
Update 2: So far, so good. None of the oddball errors.
