Trans in park beep
Old Mar 4, 2019 | 01:09 PM
repguns's Avatar
W211 4 matic
Trans in park beep
our '07 beeps when it is put in park, but the '12 does not. Am I missing this setting? I have "missed" park a couple of times lately and that beep would help!
Old Mar 4, 2019 | 04:02 PM
DennisG01's Avatar
'08 GL 320 CDI
My '08 does not beep. I have never seen a user setting (dash display/setup) for it. If it is selectable (on or off), then it must have to be done through programming.
I just look at the dash - then I know exactly what mode the tranny is in.
Old Mar 5, 2019 | 09:08 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
In fact it is the sole function of the aux battery (on the '08) to put the car in park if everything else goes 'bananas'. If you have NOT put it in park, turn the key off (or step out of the car for keyless go cars) besides beep, the lock solenoid automatically energizes even if the main battery isn't there and no other source of electricity is available.
Old Mar 6, 2019 | 12:27 PM
eric_in_sd's Avatar
2007 GL450
It is the inadequately documented "Comfort" "Easy entry/exit" feature. If you pull out the key, the steering wheel rises, the transmission goes into Park, and a chime is sounded.
EDIT: Never mind. I'm confused.
Old Mar 6, 2019 | 12:48 PM
DennisG01's Avatar
'08 GL 320 CDI
I only ever use the start button... maybe that's why I've never heard it? Or because I have never tried to exit the vehicle with it still in drive/reverse? Maybe I'll have to try it. But I do know that my steering wheel never rises by itself? Maybe that was/is an option that I don't have?
Old Mar 6, 2019 | 01:02 PM
eric_in_sd's Avatar
2007 GL450
Crikey, never mind. I don't know what I'm talking about.
Old Mar 6, 2019 | 01:24 PM
eric_in_sd's Avatar
2007 GL450
Try enabling Comfort - Easy Entry/Exit. The reason I was convinced this setting covered the chime (and shifting to Park) is my GL stopped doing the chime but started doing it again when I toggled that setting. I think the software got lost. Try it on your '12.
Old Mar 6, 2019 | 02:25 PM
repguns's Avatar
W211 4 matic
Now you guys make me feel like an idiot! I may be in a bit of a rush to get out at times, but I have pushed the park button only to have it still in drive. Obviously I am not pushing it firmly enough, no fault of the GL in my mind. I'll try the easy exit deal.
Thanks all
