Rear taillift problems.
Also it said the backup battery was faulty would this have any bearing on my problem?
thanks in advance Martin.
Have uou you checked for water intrusion around the rear Sam?
It it might just be your lock actuator has failed and any disturbance is causing it to let go.
I dont have an opening sun roof and this was bonded in like a windscreen. So took off roofrails and tiger sealed all around this and this stopped the water intrusion everywhere.
I had to remove the rear sam front sam and the gearbox ecu as all of these were wet. Dried them out at home and reassembled. Perfect except the fact that when I now start from cold the dash says dont change gear and visit workshop plus it stays in park for between 10 and 30 min. Then the beeping stops but drives like nothing wrong. No other issues.
My snap on diagnostic says communication fault with intelligent servo module. I have checked wiring to this and is normal up to connector at front right strut top. I dont think it's the ism as it's perfect when it warms up. The only bit of corrosion was at that gearbox ecu where the water was in the wiring plug so cleaned this. Also replaced aux battery in case it was bad and not letting me move till it had charged up for that warm up period in morning. There is no communication with the ism untill that warm up period is done. My question is is there a relay that turns on this ism or is it controlled by the front sam. I have no access to wiring diagrams if anyone had I'd much appreciate it. I will put up a pic of the stripping involved to find water leak as it took two days to reassemble.thanks in advance.
The way you mention it in passing makes it sound like a simple task; however, as I understand it, it requires the removal of the headliner to access the bolts from inside the vehicle... and its an ugly, tedious job as per the following thread: Urgent question regarding Roof Rails removal/installation
Much appreciated.
