p0300, p0305, p0306 codes, but only in pending status?
Now..that said, I figured I could at least run a scan to see if any codes come back, as previously per the inspection there was a P2004 code ( 0521 - Diagnosis of the tumble flap 'Inlet manifold' : Short circuit to ground of sensor wires / Tumble flap shafts are stuck in the Actuated position. (P2004)).
I assume the shop cleared the codes upon completing the work, as my scan showed there were 2 modules in this GL450, and in module 1 there were zero codes altogether, and in module 2 there were none in stored or permanent, but there were a few in pending related to cylinder misfires.
I don't know if these have been there for a while now...or recent.
The car appears to be driving fine (smooth engine, no rough idles, etc)...outside of what feels like bumpiness on the road. My concern was the intake but it doesn't feel like the car system itself is struggling, but likely suspension related as the car drifts to the right. I hope this is the case, anyways.
Is this something I likely just need to clear and see if anything comes back? I have NO check engine light currently.
Is there a fairly easy way I can visually check if the manifold is "new" without dissembling a bunch of stuff?
