How long to lower airmatic suspention
Old Jul 30, 2019 | 01:13 PM
mglsite's Avatar
GL450
I am the proud owner of a 2012 GHL 450, while checking out all of the gadgets it I was wondering how long should it take to lower it through the Airmatic?
Old Jul 30, 2019 | 01:25 PM
mrmotoguzzi00's Avatar
if it's similar to '12ml63 setup a few seconds.... takes a 5 or so to raise it all the way up...
Old Jul 30, 2019 | 01:26 PM
mglsite's Avatar
GL450
Thanks, doesn't seem to be lowering. I guess that's better than lowering and not coming back up though.
Old Jul 30, 2019 | 02:13 PM
guess your right, on the ML63 there is a button to lower and raise it... lowering doesn't go to far, raising will bring it up a good 6-8 inches ? for going offroad i assume.... i use it to lower the hitch when my boat wheel sunk....
Old Jul 30, 2019 | 03:40 PM
mglsite's Avatar
GL450
It's working, I just couldn't feel it going down.
Old Jul 30, 2019 | 09:48 PM
DennisG01's Avatar
'08 GL 320 CDI
It raises and lowers maybe 2" to 3" - or right about there. Without timing it, I'd say it takes about 30 seconds for it to fully lower. Watch in the rearview mirror as it does it - that's an easy way to see what's going on - focus on something in the mirror and take note of where it is in the mirror. It seems the front and rear lower at different times so you'll see that manifest in the mirror. You could also compare the distance from ground to the center of each wheel well when lowered/raised.
