GL 450 Need Help
Old Aug 20, 2019 | 04:17 PM
BustaZz's Avatar
Mercedes GL 450
GL 450 Need Help
Hello to everyone,
I hope here will find some usefull help.I have GL 450 Gasoline.I get Check Engine light from 2 weeks ago,clear all faults and after 3-4 days the light is coming again with same faulty codes.They are 1085 Fuel Evaporation system Major leak detected (I think its time to change charcoal canister module,right?) 1805 Speed sensor N2 signal not in range & 1781 Speed sensor N2 signal not in range.Any idea what is that speed sensors?
Old Aug 21, 2019 | 01:02 PM
eric_in_sd's Avatar
2007 GL450
Your reporting on the scan codes is all messed up.
Make sure you're using a MB-specific scan tool, like the Icarsoft i980 or MBII. Some codes are generic, and others are not. I couldn't make heads or tails of those codes with a simple search. If I were so inclined, I'd pull out my MBII and scroll through the codes, but you really ought to have such a scan tool for yourself.
