Transmission and Differential Service
Subscribe
Apr 27, 2020 | 05:45 PM
  #76
I had my local Mercedes dealership complete the transmission service after locating a $599.99 transmission service coupon from a Southern California dealership which my dealership honored.
Reply 0
May 10, 2020 | 09:17 PM
  #77
Preparing to do these services to a 90k miles 2010 GL550 now. From this thread, I should need:
Transmission: 10 L ATF 134 FE (blue) 236.15 spec.
Differentials (each): 1.3 L 75w85 limited slip 325.7 or 235.74 spec.
Transfer case: 0.6 L ATF 134 (red) 236.12 spec.
?Transmission filter? P/N : ?
?Transmission pan gasket? P/N: ?
?No malfunctions in trans so no need for conductor plate?
?What tool will the indy need to fill the trans from the bottom?
?Is there some expected volume of ATF that will drain and need to be replaced? This thread has several volumes listed.
The nearest MB dealer is 2 or 3 hours away. May consider a reputable MB independent in a larger town as well.
Reply 0
Subscribe
Currently Active Users (1)
