Need Help on how to remove Turbo
Old Oct 14, 2019 | 01:42 PM
Harinderassie's Avatar
2012 GL350 Bluetec
Angry Need Help on how to remove Turbo
Hi all, I need some major help, Can some tell detail steps on how to remove turbo on a 2012 GL350 Bluetec. I have removed a lot of bolts but the turbo is not coming out. I am not sure what i am missing. I am stuck. I live in Brampton, Ontario and need some help asap. It is moving from side to side when i push it but it does not come out. THe engine is OM642, I watched a lot of You tube videos but nothing is helping.
Old Oct 14, 2019 | 02:41 PM
espensen's Avatar
GL320CDI 2006
Hello!
Have you disconnected it from both manifolds (3 bolts each) and exhaust? There are also four bolts that holds the turbo down, two in the center and two in the back....
Old Oct 14, 2019 | 08:44 PM
2012 GL350 Bluetec
HI Sir those bolts are all removed. The Turbo wiggles a little from side to side but does not come out
Old Oct 15, 2019 | 05:37 AM
gl786's Avatar
GL320
Here’s the back if it helps.
then two in the middle, then two at the back when looking from the top.
Old Oct 22, 2019 | 09:36 AM
Fbatwork's Avatar
2012 GL350
Hopefully you already have this taken care of - google oil cooler leak, numerous videos that show the disassembly process including removing the turbo...
