lock and unlock beep
Old Oct 28, 2019 | 06:38 PM
IronPTA's Avatar
2007 Gl320 CDI 160k miles
Hello all,
I just received my C4 and 07.2019 Xentry set up from eBay. If you want detail on price and seller let me know.
I am trying to find the ATA version and change it to USA beep. When I go to control units>Body>Rear sam>control unit adaptations>read coding and change if necessary> I get the attached image. The ata version is not there. I have also exhausted the options in developer mode. I did find a ROW and US variant for PWM Ueff 5W.
Does anybody know how to enable beep when locking and unlocking?
Old Oct 30, 2019 | 11:57 AM
DarthVaderpa's Avatar
X166 GL550
Can you provide detail on price and seller of the C4 and 07.2019 Xentry set up?
Thanks in advance!
Old Nov 4, 2019 | 10:07 AM
WaveyKat's Avatar
Something Slow
yea i tried that unlock beep stuff didn't work on my X164
Old Nov 6, 2019 | 07:25 PM
bha's Avatar
bha
13 GL350, 14 SL550
I think we figured out in another forum (or maybe it was here, not sure) that there is an "alarm siren" installed in many markets of this truck, but not in the US.
It seems that the regular horn isn't used for the chirp. The alarm siren is.
So no matter what you program, you need to install a fuse and an alarm siren.
We figured the price was reasonable (can't remember but it was definitely well under $100) but I don't think anyone ever tried it.
Would be interesting to install the fuse, hook up a voltmeter to the connector, then lock the truck. If it shows voltage then you could go buy the alarm siren.
Look it up in a parts catalog.. or search around and see if you can find the previous posts. If you do it let us know how things turn out! There are quite a few people that would be interested in buying the siren if you can get yours to work (me included!!)
Old Nov 7, 2019 | 12:53 PM
chassis's Avatar
2017 GLE350 4MATIC
On the W166 using the steering wheel buttons in the MFD:
“Sett.”
Down arrow to “Acoustic Lock”
enable or disable as desired
OK
back out to desired menu
The beep is very low/quiet and uses the main vehicle horn.
Old Nov 7, 2019 | 07:36 PM
lkchris's Avatar
'10 CL550, '12 GL550
It’s a really loud clunk when the doors lock or unlock. Doesn’t really need to be just like a chebbie, does it?
Old Apr 10, 2023 | 02:31 PM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
Any answer to this?? I'd like to turn on my horn sound.
Old Apr 10, 2023 | 02:51 PM
bha's Avatar
bha
13 GL350, 14 SL550
I was never able to get it to work. I think it required the coding PLUS you needed to add the anti-theft horn/siren. It doesn’t use the regular horn to do the lock chirp, it uses the alarm one (which does not come with your truck in North America)
Gave up after playing with it for a bit. I’m pretty sure it would have worked if I ordered the alarm horn. I’d try to find the connector and put a light bulb or voltmeter on it, then lock the car (after programming it). See if current goes to the horn connector. Then you know the horn will work if you order one. Wasn’t expensive ($100 or less..maybe around $50 if I remember correctly?)
Old Apr 10, 2023 | 04:15 PM
eric_in_sd's Avatar
2007 GL450
Pretty sure the X164 owners are out of luck.
Anyone know what "flashing brake light" is? As stupid as people are becoming on the roads, it might be helpful avoiding getting rear ended.
Old Apr 15, 2023 | 01:51 PM
lkchris's Avatar
Euros like the idea of brake lights flashing, but it's illegal in USA ... a thing with BMW motorcycles, too. Can't possibly look like an authorities vehicle is the reason.
Old Apr 15, 2023 | 01:58 PM
Sallad's Avatar
Veteran: Army
08 GL320 CDI
Im not talking about the "chirp" sound, I mean the actual horn honking when you lock the doors. I keep reading different things. Does the X164 have the ability to make a horn sound when you lock the doors??
I've seen this before. The lights flash three times then stay lit until you release the brakes. Looks cool IMO
Old Apr 15, 2023 | 06:04 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Old Apr 15, 2023 | 06:09 PM
Sallad's Avatar
Veteran: Army
08 GL320 CDI
^^ Can you please increase your font size, I cant read that.
Old Apr 17, 2023 | 03:40 PM
eric_in_sd's Avatar
2007 GL450
Alas, apparently this calls for some electronics option, because I tried enabling Flashing Stop Light and (a) it warned that some option was needed, and (b) nothing changed about my brake lights.
Old Apr 17, 2023 | 08:27 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Pretty sure the flashing brake light will get the attention of every John Law behind you.
Old Apr 18, 2023 | 09:29 AM
eric_in_sd's Avatar
2007 GL450
Fair point.
It might also irritate drivers behind me to the point they rear end me on general principles, just to extinguish the damn light.
I guess I'll have to stick with the "pedal" method: Tap the brakes when making a potentially unexpected stop.
