Brake Bleeding Question
Old Oct 31, 2019 | 12:35 PM
DennisG01's Avatar
'08 GL 320 CDI
Can the brake system be bled the "normal" way (power bleeder hooked up to brake reservoir, for example)? Or does one HAVE to use STAR? Or do we only need STAR if we mess up and introduce air into the system? Sorry for the likely simply question, but in googling, I'm getting mixed answers.
Old Oct 31, 2019 | 02:25 PM
Benztech858's Avatar
2004 E55 - 2010 GL450 - 2011 GL550
Pressure bleeder on the reservoir between 10-15psi. Start on the right rear then left rear then right front lastly left front. Should all be 11mm.
Old Oct 31, 2019 | 03:11 PM
DennisG01's Avatar
'08 GL 320 CDI
Perfect, thank you! I have a MityVac 7201 (8qt.) and have tried using that (vacuum, right on the bleeder screw) on other vehicles. But I always seem to get air bubbles - which I assume is air leaking in around the MityVac's rubber fitting that snaps onto the bleeder screw. But it made me nervous that somehow air was getting into the brake system... although logically I know that's not the case. Maybe I just need to trust logic! On the other hand, a pressure bleeder would be a little faster since I wouldn't have to keep monitoring the brake reservoir.
Old Nov 1, 2019 | 09:33 PM
eric_in_sd's Avatar
2007 GL450
Yeah, get a pressure cap for the reservoir.
Suction out the old fluid (empty the reservoir). Put in fresh fluid. Put on the pressure cap. Very low pressure is plenty. It's so easy it seems weird.
Using 1/2" ID tubing, I made a doohickey to moisture test the fluid coming out of the caliper.
The furthest caliper will about drain the reservoir, so you have to refill it before going on to the next.
Old Nov 4, 2019 | 12:48 PM
sak335's Avatar
2012 GL 350
Yes, you can pressure bleed. Usually, that means that you won't be swapping the fluid that is inside the ABS pump, but it's so minimal that it's not an issue.
The reservoir cap is standard issue Ate so any pressure bleeder for a BMW or most other euro car will work.
Old Nov 4, 2019 | 03:48 PM
DennisG01's Avatar
'08 GL 320 CDI
Think I'll be buying a power/pressure bleeder soon! Thanks for the input, guys!
Old Nov 5, 2019 | 10:19 AM
sak335's Avatar
2012 GL 350
Here's my setup. Obviously that's not a GL, but I was bleeding brakes last night so figured I take a snap.
Old Nov 5, 2019 | 07:41 PM
DennisG01's Avatar
'08 GL 320 CDI
Yup - that's what I'm gonna do. In fact... just ordered the power bleeder right now. I've actually had a Motive power bleeder for about 10 years - but I bought it to convert it to a marine gearcase filler. Got nice, internally valved fittings so there's no mess when I disconnect, too (fittings automatically close when disconnected).
Side note... did you cut the concrete floor so that lift fits flush into it? You're sick! ...and I'm jealous!
Old Nov 5, 2019 | 09:51 PM
sak335's Avatar
2012 GL 350
"Side note... did you cut the concrete floor so that lift fits flush into it? You're sick! ...and I'm jealous! "
Yes, that's exactly what I did. Even though the lift is very low profile and designed to just bolt to the floor, the race car didn't really clear it, so I cut the concrete and poured a 12" deep footer to hold the weight, and then poured recessed boxes to hold the lift.
Old Nov 6, 2019 | 08:07 PM
eric_in_sd's Avatar
2007 GL450
I take it the slab was not post tensioned.
Old Nov 11, 2019 | 09:40 AM
sak335's Avatar
2012 GL 350
I'm not familiar with residential construction in California, but I've never seen a post tensioned residential slab on the east coast. I've done a ton of construction, including being on the PMO on the 5th tallest building in Manhattan, and PT slabs are not super common due to engineering complexity vs benefits. Which is a long way of saying that this is just a re-bar slab. I poured 5,000 PSI concrete 12" thick underneath which was total overkill, but then again, I already had the concrete truck in the driveway so may as well make it bomb-proof.
Old Nov 11, 2019 | 12:12 PM
eric_in_sd's Avatar
2007 GL450
Slab on grade is common around here, so I think the strength of the slab with respect to the rim, and for seismic strength, is more important.
12" thick. Hm, I've been getting concerned about Antifa here in Commiefornia. You sound like the guy to hire to build a pillbox machine gun nest.
Old Nov 11, 2019 | 01:37 PM
sak335's Avatar
2012 GL 350
Not much better this < > close to Philadelphia. If we learned anything from the Germans rolling over France in 1939, it's that a good offense is better than digging in. My advice is to mount a .50 cal in the bed of a Tacoma.
Old Nov 11, 2019 | 02:07 PM
eric_in_sd's Avatar
2007 GL450
Please. This is a GL forum. Let's discuss popping out the back roof glass so the .50 can be mounted on the roof and you can shoot facing forward or rear, standing up through the sunroof.
