Premature Inside Tread Wear
However, note that K-Mac says the rear camber is adjustable; the kit they sell increases the adjustment range.
I'm real tempted to see what I can do on my own.
Unfortunate - as we do offer BETTER RESULTS (AND PRICE).
KMAC Front "upper wishbone adjuster" not just Camber but importantly "Caster" as well to cater for the new Camber settings also allowing to correctly resolve steering pull (along with half the time to install).
Also not to void warranty, KMAC is not welded, fabricated steel but retaining the security, integrity (and peace of mind) of the existing OEM/factory forged alloy high strength arms.
While KMAC rear - not just Camber but extra TOE as well - necessary to compensate for the additional Camber settings.
KMAC Rear unlike your upper arm adjuster also retains important clearance top of tire to outer fender when adjusting to reduce premature inner edge tire wear.
As mentioned in previous reply GL suspension there is no facility for crash bolts. Besides they only offer inaccurate one offset position - and a minimal 1/8" (0.3 degree).
While KMAC front and rear adjusters provide up to 1.5 degrees Positive or Negative and are precisely accurate (direct on alignment rack under load)
On the rear, there is a massive lower control arm, which carries the shock absorber and the spring. There are two upper arms, one at an angle and one with a bend:
At the inside mounting point of the upper arm
is a cam bolt, with an eccentric washer:
The rearward nut locks it in place; the bolt head can be turned once the nut is loosened:
Turning the cam so its low point faces out moves the control arm mounting point out, making the camber less negative:
The previous alignment had shown 2 degrees negative camber. Rotating the cam bolt to the most positive position added about one degree, so the camber should now be one degree negative. Maybe this will help with my inner shoulder wear.
It's a mystery to me why the GL ships from the factory with so much negative rear camber. Hope this helps.
