Warm heat
If its anything like a W209, the engine must reach operating temperature for the thermostat to open and the heater core pump to circulate fluid.
Green antifreeze should not be ran in the OM642 because of the various types of dissimilar metals within the engine (Aluminum block/heads, brass/bronze sensors, steel water pump impeller, etc..). When exposed to electrolysis, not having the right amount corrosion inhibiters can cause the surfaces of those metals to pit and corrode over time.
The spec antifreeze for it is MB 325.0 aka Blue G48 or Yellow G-05. Both are relatively plentiful at a local NAPA and cheap.
What does the engine temp get up to? You can check this in the dash display.
