Gl450 electrical issues
Old Feb 6, 2020 | 02:33 AM
2001e430's Avatar
Right marker light stays on after car is shut down and locked up. Also the turn signal will stay on. Have new battery. Now I also have ESP warning at random intervals. The battery symbol will also display after starting the engine. The ca starts and runs fine. I also discovered water in the battery compartment. ??? HELP! Oh, the left passenger window will lower at small increments as my left turn signal is on.
Old Feb 6, 2020 | 11:03 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Well, it seems that the SAM module at the battery compartment has a short due to the water. I recommend to remove the module to dry it, but first you have to remove the main and auxiliary batteries.
Old Feb 6, 2020 | 02:35 PM
lkchris's Avatar
'10 CL550, '12 GL550
... and you’ll probably need a new SAM.
