Need help: Replacing front ball joint rubber boot
The first picture shows the left side, whose rubber boot is in good shape. The second picture shows the right side, which shows the problem. I think it happened when I used the ball joint separator, the separator must was clamped on the bottom flange of the metal collar, so when the ball joint popped out, they got separated. The picture shows clearly the problem.
I tried very hard to put the pieces back into their position but failed, During the process, I also kind of damaged the rubber boot's bottom part (the little rubber flange below the groove, torn a section of the flange (1/4" to 1/2" long).
Anyone has any suggestion how to fix it or what tool to use to fix it?
Or better yet, is it possible to buy the boot and just replace it? Where to buy it and what's the part number? I tried to search but can only find the whole upper control arm for sale (Is it called upper control arm?)
Thanks!
