P0456
Old Mar 6, 2020 | 05:25 PM
WinterPark321's Avatar
2009 E550, 2011 GL550, 2013 GL550
P0456
I was driving home today and the "check engine" light appeared on the dash. Scanned it and got the code P0456:
Has anyone experienced this code?
Old Mar 7, 2020 | 09:48 PM
chassis's Avatar
2017 GLE350 4MATIC
Possibly a fuel fill cap not tightened sufficiently?
Old Mar 7, 2020 | 10:58 PM
I checked fuel cap and it was tightened.....
Old Mar 8, 2020 | 09:34 AM
Miguk_Saram's Avatar
'07 GL450
Check again.
Clean the fuel cap gasket with silicon grease (or replace it); and the metal contact on the vehicle with petroleum jelly. Wipe dry, and ensure it is free of any rubber debris. Do not clean the gasket with petroleum jelly since it will eventually eat through the rubber.
When your fuel cap is properly sealed, you should hear a bit of a suction sound when you release the cap to refuel (this is indicative of proper vacuum),
It will take a couple of cold starts for the MIL to reset.
