2012 GL350 Bluetec Overheating and AC stopped working as well at same time
Need help.
Thank YOu
The only reason I know that is because I gave my GL320 the beans on one 0-60 run and wound up with no A/C for a day in the 110 degree desert.
It came back the next day as if by magic, or cruel fate, ****ty engineering or all of the above.
If you haven't checked the coolant level, do that.
If that's fine check for radiator blockage.
If that's fine have your car read for any codes and go from there.
Water pumps rarely fail without causing massive leaks so you should see this at step 1 if that's the culprit.
