Locked out. Help..
Old Jun 10, 2020 | 03:15 PM
Richard Tammi's Avatar
'07 x164
Unhappy Locked out. Help..
Got a call from a neighbor last night to tell me that my left park light was on, so I went out and turned it off, h/l switch got nocked to left park light position. This morning can’t unlock with fob or key into lock ,seems battery is dead ,was replaced a year ago new batteries in fobs. Key will turn to lock position but not to unlock. Started having problems with both rear doors not unlocking with fob. How in the H! do I get into this thing short of a cutting torch. Any help GREATLY appreciated.
Old Jun 10, 2020 | 04:13 PM
E55Greasemonkey's Avatar
This place is a joke.
Insert and turn blade in drivers door tumbler, hold in position, pull drivers door handle rapidly several times.
Old Jun 10, 2020 | 04:15 PM
'07 x164
Update,got Caa to come out and they used 2 little airbags and a cable with a grasper on the end and popped it open in 2 minutes. Charging the battery now. The start of a new adventure.
Old Jun 10, 2020 | 05:01 PM
DennisG01's Avatar
'08 GL 320 CDI
FYI... leaving that park light on overnight shouldn't kill the battery. That's exactly what that park light is designed for and the battery in these vehicles, like many German cars, are very large. Charge it up - but then get it load tested.
Old Jun 10, 2020 | 08:31 PM
'07 x164
Battery is 1 year old Oem but I wonder if the rear door lock problem is involved. Will get load test done. Thanks
Old Jun 11, 2020 | 03:21 AM
Max Blast's Avatar
NGL450 w/EORP, S550
what e55 grease monkey said...
Battery should not drain with lights in Park overnight, have you noticed slow cranking in the morning?
Old Jun 11, 2020 | 06:35 PM
'07 x164
Cranks fine when the battery is charged 🤒 but I suspect it’s no good. Going to get it loao tested. Thanks
