Rear Slammed After Sitting for Days; Raises Once Driver Door Opened
Of reference, I had the both rear tie rods, both rear hydraulic shocks, both lower rear shock bushings on the control arm not to long ago.
have them replaced before your compressor burns out from running all the time.
buy arnott or Bilstein brand airbags - it’s 15 minutes a side if you’re an experienced DIYer.
If the air suspension is in normal (non-raised mode), the rear will sag after a few days. But, if the vehicle is parked in raised mode, it keeps it height and doesn't sag.
If the bag had a leak, wouldn't it still leak in raised mode? I do agree with you and feel these bags are at their end of life, as they have never been replaced. I just found this observation strange.
so you are now way behind the power curve on this, I now recommend both bags and a new compressor.
