View Poll Results: Which would be most reliable?
2012 GL 550
1
50.00%
2013 GL 450
0
0%
2013 GL 550
1
50.00%
GL 350
0
0%
Voters: 2. You may not vote on this poll
2012 Gl 550 vs 2013 Gl 450 reliability?
Old Jul 19, 2020 | 09:24 PM
MatW's Avatar
GL 550
Hi, shopping for an SUV to tow my 7000lb 26ft travel trailer.
I already researched on how to reinforce the tow hitch so that I'll stay within spec for the tongue weight.
Big question is what type of engine would be more reliable long term - 2012 GL 550 or 2013 GL- 450 (if I find a deal I would consider 2013 550)
opinions welcome.
Thanks!
Old Jul 19, 2020 | 10:26 PM
Max Blast's Avatar
NGL450 w/EORP, S550
They’re damn near the same, there’s really no difference in the alternatives you’ve provided; except for the 350.
It sucks.
Old Jul 20, 2020 | 12:17 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
2012 GL550 is naturally aspirated and is very reliable.
Old Jul 20, 2020 | 12:47 AM
MatW's Avatar
GL 550
is it enough power for 7000lb trailer? I live in WA state so we have some mountain passes here...
Old Jul 20, 2020 | 09:10 PM
BlownV8's Avatar
Yes, it's a strong V8 and will have no issues towing but you will need to run premium unleaded. The later bi-turbo V8's will work even better but with turbo vs NA you give up some reliability for the extra hp.
Old Jul 20, 2020 | 09:20 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
I tow a boat/trailer that weighs somewhere between 7000-7500 lbs with my 08 550, and power is not a problem. I haven't towed in the mountains, but it doesn't have any problems getting up to speed on an uphill onramp, so I'm sure it would do fine. The transmission seems to go into a trailering mode once the trailer is connected and holds gears quite a bit longer than normal before upshifting which helps. I definitely feel it behind me though. It doesn't feel overloaded, but you know you have something substantial behind you. Putting the suspension in sport mode firms things up and helps.
I'd go for the 2012 over the 13 because the 12 is the last year of the X164 series with many years of production to fix problems vs. the first year of X166, which from what I've read here has more issues in general than the X164s.
Old Feb 3, 2021 | 05:48 PM
MB33's Avatar
GL450
for this poll, perhaps it would have been helpful to list out the various engine type of the 450. in the 2013 version one could have the turbo (4.7) which is essentially the same as gl 500 without the tune
