air shock exploded
Old Jul 31, 2020 | 05:01 PM
pgreen413's Avatar
2009 gl450
air shock exploded
my 2009 gl450 was sitting in my driveway, I went outside and noticed is was leaning really bad. took the right wheel off only to see the air bag had actually popped.
I replaced it and the new one will NOT air up. The compressor is working, it is only a month old. Could it be a bad shock? or What I need help
Thanks phil
Old Jul 31, 2020 | 10:26 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Ok...which one - front right? If you dont get that bag sealed over the old shock it’ll never inflate. Usually it’ll “pop” in upon first inflation.
Dead shocks won’t cause lean, just bounce. If you found excessive oil in the shock towers or signs of leakage when you removed it then it’s done.
Old Jul 31, 2020 | 10:39 PM
pgreen413's Avatar
2009 gl450
it is the right front. The air bag is attached to the shock, new in box as 1 piece.
Old Aug 1, 2020 | 11:14 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Check your hose connection first then the level sensor on that corner. The exploding bag may have broken or bent it.
Old Aug 4, 2020 | 12:05 PM
lkchris's Avatar
'10 CL550, '12 GL550
To be pedantic ... it’s an air spring. At the front it’s combined in a single unit with a hydraulic shock absorber. At the rear, the two components are separate.
