airmatic malfunction warning on dash?
Old Sep 15, 2020 | 01:12 PM
1xsculler's Avatar
GLS450
When I first start my car and drive all is ok but after some miles, i.e. 10 to 50, the Airmatic Malfunction light shows in the cluster. The car rides like normal at a normal level the entire time BUT my Owner's Manual says drive no faster than 50 mph even though I cruise the freeways at 70+.
Will an auto parts store OBD scanner tell me what's wrong or is this a dealer only item?
Old Sep 15, 2020 | 01:52 PM
carlosrg's Avatar
2023 EQE AMG
You will need an OBD II scanner such as Star Diagnostic or
iCarsoft MB II iCarsoft MB II
to read the fault codes. To me it saying that something is wrong.. it could be that the pump is dead.. Have you tried to raise the truck?
Old Sep 15, 2020 | 02:01 PM
1xsculler's Avatar
GLS450
Yes, I can raise and lower the truck.
Old Sep 15, 2020 | 09:27 PM
Max Blast's Avatar
NGL450 w/EORP, S550
With a DAS or IcarSoft you'll probably read out a compressor run time exceeded or compressor overheat code related code. Or perhaps one of your level sensors is sending implausible signals. A scanner doesn't really provide dead giveways when troubleshooting Airmatic issues (as it does for other on board systems or sensors), it merely hints to where you need to put your eyeballs and look for leaks.
If your malfunction indicator is the white car symbol with the up arrow through it it is usually compressor related - either it is not providing output when commanded, or the output falls below threshold (16 bar in 30 seconds).
Check relay, check that compressor runs when pushing the raise button, check your bags for leaks with soapy water or leak detector spray before investing in a code reader.
Old Sep 16, 2020 | 06:16 AM
S-Vibes's Avatar
2010 GL350 BLUETEC, 2013 E350 Sport
Ditto to that, but don't think too hard about the investment for something as inexpensive as a MBII scanner. It will save you a huge amounts of time and cost in dealing with the many inevitable CELs you will experience with these vehicles. Pays for itself many times over.
Old Sep 20, 2020 | 04:13 PM
1xsculler's Avatar
GLS450
icarsoft MBll to diagnose Airmatic (Problematic, a better name) malfunction
So, I connected my icarsoft MBll, scrolled to Airmatic and got this message, "Recovery time during filling of central reservoir is too long", now, what do I do with this? I have a new Arnott compressor and a new valve block at the ready but I have no way of knowing if either of these will solve my "Airmatic Malfunction" warning. I have no sagging on any axel or corner and other than the warning on the dash the car acts absolutely normally.
Old Sep 21, 2020 | 10:17 AM
Max Blast's Avatar
NGL450 w/EORP, S550
That says your compressor isn’t putting out enough PSI to fill the reservoir when commanded to.
change your compressor and that will go away - but ask yourself why your compressor is worn out. Have you checked the air springs for leaks?
Old Sep 21, 2020 | 10:45 AM
1xsculler's Avatar
GLS450
icarsoft MBll vs the dealer's Star scanner?
Thank you very much for your reply. I think I read on a related post that the dealer's scanner (MB Star or On Star, ???) would pinpoint the problem to the compressor, the valve block or an individual air bag at which corner of the car? Is that correct?
Thanks again.
Old Sep 21, 2020 | 11:37 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Not entirely correct, just generally. See reply in your other thread.
