icarsoft MBll vs the dealer's scanner (Star or On Star or ???)
Max replied that if I change my compressor the problem would be solved but that I need to find out where an air leak might be, also, so I guess I'd better go through the soapy water routine at all air line connections at the four air bags and at the valve block.
I think I've read that the dealer's scanner (Star or On Star, or ??) can pinpoint the problem as to where the leak, or other problems might be. Is that correct?
a visual inspection is required before swapping airmatic parts.
your compressor could just be tired from age - can you read out the runtime with your scanner?
if the bags show evidence of having been replaced and don’t leak, I would leave them alone for now.
I replaced both rear bags with new Arnotts about 10k miles ago and, if I remember correctly, Arnotts were already on the front.
when you install a new compressor you zero out the run time.
hopefully your system can do that.
