Help needed
Old Nov 26, 2020 | 04:01 PM
taeandji's Avatar
Help needed
Hi, I've been trying to remove turbo on GL350 to replace the oil cooler gaskets.. I do not have enough clearance to remove those bolts on the rear of turbo and need help on how to remove cowl/firewall shield to have better access to rear.
Thanks and have a happy Thanksgiving!!!
Old Nov 26, 2020 | 11:22 PM
taeandji's Avatar
No one?
Old Nov 27, 2020 | 04:26 PM
expl0rer's Avatar
GL550 X164
I wouldn't be able to help with actual instructions, but have a look in the W164 forum. The ML and GL platforms are similar. You might be able to find docs outlining the procedure you need help with.
Old Nov 27, 2020 | 09:42 PM
taeandji's Avatar
Thank you!
