Towing with a 2013 GL450
I know the towing capcity is 7500. If I'm looking for a trailer, what should it weight be with everthing in it such as cargo, food etc. My wife and I are currently looking at trailers that are approximately 9000, which I know is over the trailer capacity.
How efficient is towing a camper cross country or locally? What repairs, maintenance etc should I be looking out for. How many miles should I drive up to before it's no longer worthy to put pressure on engine and other parts. I currently have 137000+ miles on the vehicle. Thanks for your responses in advance.
Trailer weight plus food, clothing, dishes, televisions cannot exceed the vehicle tow rating. The trailer dealer can help with this, or estimate approx 10% of the dry trailer weight for its contents. This means a 6k lbs dry weight trailer is getting close to the limit.
At that trailer weight you will want a weight distributing hitch. Are you familiar with these?
Fuel economy goes way down when towing, not a surprise. Brakes get consumed faster, as do tires, but to a lesser extent than brakes. You will want an electric brake controller with a 6k lbs dry weight trailer.
I'm curious about the videos you make as I know nothing about how youtube works. Do you make money whenever someone clicks on your videos? It seems like you post these videos you make a lot and I was curious about it.
Yes he makes money off clicks on his YT videos, which doesn't mean the content is wrong, but it is unethical to promote your own information without disclosing your financial incentive - making the information automatically suspect. The clickbait UR GONNA DIE headline doesn't help either.
This crazy U-Haul guy told me I would flip my car if I put the safety chains on wrong. I had no idea he was renting me such an unsafe product.
1) Respect the limitations. Towing is unnerving at best, if not change-of-underwear time.
2) You're playing with fire if you heavily load the tongue, because the rear air springs have to run at high pressure to maintain level.
3) Weight is less of a concern than is trailer wind cross section. A locomotive can pull many times its own weight, because each car has its own brakes and the rails prevent sideways movement. A camper trailer, as opposed to a cargo trailer, is mostly air inside. Both may be 6k lbs loaded, but one has several times the cross section. You get a strong sideways gust, like from a passing semi, and, well, hope you brought a change of underwear.
It really isn't what I would do. I value my peace of mind and sanity more than that.
However, it all depends on your relationship with your wife. Put her in the trailer when you're on I-80 over the Rockies, and the semi trucks blast through at 75, and you'll find out how she responds to stress.
However, this is a good example of how "just because someone makes a video, doesn't make it true". For example... first, it's GVWR, not GRVW (could be a typo, but then whatever happened to proof reading?). However, unlike what is stated above in post #4, GVWR has nothing to do with trailer weight. It only deals with trailer tongue weight and people/cargo in the truck. GCWR tells us more - but you then first subtract the trailer weight and tongue weight and whatever is left is the amount you can put in the truck.
Since you are making money off your posts, and presumably have cash to spare anyway, being a super successful care salesman, why don't you do the noble thing and become a MBWorld sponsor?
Or take the text from your video and post it, so people don't have to give Youtube the traffic? That would be the selfless thing to do.
People have to eat, but forums such as this are comprised of people crowdsourcing knowledge. It is volunteer work. Grifters taint the water.
I used to buy leads from their CarsDirect since 2004 for 3 different MB dealerships, so I already invested my part.
Next time I'll provide you with a text instead of the video if that's what you prefer. Maybe you suggest to MB World, since you sincerely worry about traffic, to remove the embedding of YouTube videos altogether, and just use text.
