Code P0101 or 2645-1 Mass Air flow Sensor "FIXED"
Old Feb 9, 2021 | 07:39 PM
jrtor's Avatar
gl 320 cdi
After trying for over 3 months to get this code out of the vehicle, I finally took the car to Mercedes Benz shop and get this fix. It started when I replace the y shape intake tube because it cracked on me. After installing the new part, check engine light came on. Did search on different forum and did different solution to remove this code, with no success. Here what Mercedes Benz did to fixed it. "RESET ADAPTATIONS FOR AIR MASS SENSOR THAT IS REQUIRED AFTER SENSOR REPLACEMENT. FAULT NOW WAS ABLE TO BE ERASED". I just want to share the solution just in case you have the same problem. Total charge is $168 for labor.
Old Feb 9, 2021 | 09:13 PM
Max Blast's Avatar
NGL450 w/EORP, S550
There’s no y shape in the x164 intake manifold, gas or diesel. Do you have the right forum?
Old Feb 12, 2021 | 01:56 PM
sak335's Avatar
2012 GL 350
I think he's referring to the inlet tube for the turbo, which is sort of Y shaped.
Old Dec 7, 2021 | 04:10 PM
Yemiii's Avatar
Rclass
Hello
Jrtor , glade you are able to fix the problem
I’m having them same p0101 that will not clear. Can you please confirm your experience with the code after erasing it? Did the code return after 2nd engine start?
Thanks in advance
FIXED
