Drain holes
Old Feb 17, 2021 | 10:08 PM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
Drain holes
So I having an issue that requires me finding out where the drains are in my 2008 Mercedes Gl450. Obviously my amp under driver’s seat got water and I been told that somewhere one of the drains are clogged so I want to clean them all so when the amp is repaired that it doesn’t happen again. Can anyone point me in the right direction with a diagram of where these drains plugs are where the water drains out of the car when it rains or if I go into a car wash.
Old Feb 17, 2021 | 11:00 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The water is most likely coming from the roof rack. Inspect the rubber pieces around the base and if you see they are cracked, shrunken, or missing chunks, that's the intrusion. Can be solved with some tape and black silicon sealant. You don't necessarily need the tape but it makes the finished project look much nicer.
