Speed Sensor failures
All this was to recommend to others...save yourself the headache and replace all of them once one fails if you have a higher mileage GL. It's really easy to do, which is nice
that would be the vehicle speed sensor on the valve body in the transmission. Known issue.
failing wheel speed sensors (easy fix) are always changed in axle pairs and if not; result in ABS, ESP, diff overheats and sometimes variable speed steering errors. I’ve never heard of these triggering transmission errors such as locked in gears or neutral pops.
