GL 550 2011 with electrical problem
Old May 30, 2021 | 05:07 PM
Dmayeda's Avatar
s430
I have a 2011 GL 550 with about 200K miles. It has been very reliable... until now.
Brake wear message goes on, usually when I first start the car. I had the brakes checked for wear and was told they looked good. I reset the light by pushing a button on the steering wheel.
Recently when I make a slow sharp turn, usually to the right, I get a proximity beep and at the same time the brake check light goes back on.
Has anyone else had these electrical gremlins?
Thanks in advance,
Dave
Old May 30, 2021 | 05:41 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Probably just a bad brake wear sensor. They are cheap and easy to replace.
Old May 30, 2021 | 07:21 PM
Dmayeda's Avatar
s430
Yes, Has been replaced on both front brakes.
Thanks for the thought.
Dave
Old May 30, 2021 | 09:26 PM
Max Blast's Avatar
NGL450 w/EORP, S550
The harness to one of your front brake wear sensors has an intermittent short. Replace.
Old May 30, 2021 | 09:38 PM
E55Greasemonkey's Avatar
This place is a joke.
He's correct. You'll need to replace that harness. It looks just like the wheel speed sensor harness on the right front.
Old May 31, 2021 | 12:05 AM
Dmayeda's Avatar
s430
Got it. Will give it a try.
I'll keep you posted with the results.
Many Thanks,
Old Jun 8, 2021 | 10:47 PM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
oh bridge the wire to ground or code out the sensors
