2011 Gl550 with 200k chuddering
My very reliable GL 550 has started chuddering (if that is actually a word) when accelerating from a stop or at low speed while climbing up a small grade. There are no indicator lights on. My mechanic placed some gas additives to clean the injectors but has not really helped. Other potential problems he threw out there was possible fuel pump, but without any indicator lights illuminated the diagnosis is just guessing.
Any thoughts?
Thanks in advance.
Dave
Any thoughts?
Thanks in advance.
Dave
Max Blast (07-04-2021)
chassis (07-04-2021)
Thanks for the input
For those that remember what it was like to drive a stick (manual transmission),
The chuddering feels like starting in first gear and releasing the clutch too quickly, just before the stall. Or starting in second gear.
Driving this weekend the chudder was felt again at low speeds but not at high speeds climbing hills.
Performance otherwise was been very good.
I noticed that if I feel the chudder going up a steep grade, like on a dirt mountain road, if I manually use the paddle shifter to get a lower gear I seem to be fine.
I know it's difficult to make a diagnosis via the internet but does this sound more like a power train problem (torque converter, etc) or a fuel management problem (injector, spark plug, fuel pump).
Once again TIA
Dave
Once again TIA
Dave
2011 GL 550, 2010 MB S550, 2004 BMW 645Cic 1988 Corvette
The Thomas J (07-11-2021)
I have the 550.
Just so we're all on the same page here, no matter what gear you're in or how fast you're driving, if you double tap the gas pedal twice it will always drop a gear for acceleration purposes, correct?
Never tried that…but to be sure just use the flappy buttons on the back of the wheel to manually shift.
when you start off normally downshift one gear, you’ll feel the shift and the center screen should read D1. Which means you started out in second. Other 7G implementations such as the R class has a Sport / Comfort button that in Sport starts out in 1st gear.
Has anyone tried Instant Shudder Fixx by Lube Guard in the X164 to improve or resolve these type of symptoms?
I do 100% agree with anyone who says they don't believe in the magic bottle fix, but the reviews on Amazon and YouTube are hard to ignore...
i wouldn’t try this. I find the reviews on Amazon and YouTube hard to believe most times.
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (for sale)
The failing motor mounts on my '14 GL450 caused a shudder on acceleration that went away after 10-15 mph. Then if you were driving at say 45 mph and got on it a little, you felt the shudder. Dealer replaced under CPO warranty Aug 2017 at 46k. Now at 80k with no reoccurrence.
And most liquid fixes just gum up the works to hide, not fix, problems.
That transmission will cost you thousands to replace, plus it's a headache considering the electronics have to be programmed to your VIN. Not in a million years would I consider putting additives in the fluid.
I`m a bit skeptical about the additives and not using anything, tranny, engine or any other fluids, just do your oil changes, fluid changes in time, keep the levels sufficient and its good. The rest is marketing gimmicks.
eric_in_sd (10-24-2023)
