Engine have same noise
Old Aug 3, 2021 | 08:28 AM
lunskis's Avatar
gl550
What’s can be? Maybe someone know the problem?
It’s going when engine is on neutral 1st gear but when i going faster and have power the noise gone.
thank you
File Type: mov
Old Aug 3, 2021 | 11:55 PM
Max Blast's Avatar
NGL450 w/EORP, S550
What engine is this
Old Aug 4, 2021 | 08:40 AM
lunskis's Avatar
gl550
Gl550
Old Aug 4, 2021 | 09:38 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
It can be some of the following issues:
Air conditioner compressor;
Power steering pump;
Belt tensioner;
Idler pulley...
these are the most common issues.
Old Aug 4, 2021 | 05:01 PM
lunskis's Avatar
gl550
Thank you guys.
Old Aug 6, 2021 | 09:02 AM
Yup497's Avatar
2010 GL550 | 2020 S560
I have a 2010 GL550.
Does the ticking increase when press the gas pedal?
When I replaced my serpentine belt,, it came in a kit that included two (2) pulleys, one (1) belt tensioner, and of course the belt.
The only the that was genuine Mercedes parts was the belt.
On a cold start, one of the pulleys will make a similar noise but stops after about 45 seconds.
Have you checked the oil? This sounds similar to a lifter.
