Interesting OM642 dissection
Old Aug 18, 2021 | 01:50 AM
Max Blast's Avatar
NGL450 w/EORP, S550
https://m.youtube.com/watch?v=_j9vMzgnyfc
my main takeaways:
1. Change your oil
2. 642 seems to be a very stoutly built engine
3. The egr system causes intake flaps to fail
yours may vary but it’s worth a watch.
Old Aug 18, 2021 | 10:27 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Puddin! From what I read, the spun bearing is fairly common due to the manufacturer recommend oil change intervals of 10k miles. Hard to believe that synthetic oil would sludge that badly. Yes, change the oil 2x as often as what is recommended by the factory.
Old Aug 18, 2021 | 12:49 PM
DarthVaderpa's Avatar
X166 GL550
That engine had a serious water leak problem. I guess the head gaskets.
Old Aug 20, 2021 | 04:48 PM
acsavage's Avatar
2008 GL450
How do you know it had a water leak? I would assume the oil would be brown and frothy then. That looks like egr failure and carbon from diesel to me. That's just black as the night.
Old Aug 20, 2021 | 07:35 PM
Max Blast's Avatar
NGL450 w/EORP, S550
I think I heard the guy say that it was removed from a 2013 model in 2015…and that there was no evidence of oil change.
Old Aug 20, 2021 | 09:11 PM
DennisG01's Avatar
'08 GL 320 CDI
It's synthetic oil. You never have to change it.
Old Aug 20, 2021 | 09:12 PM
DennisG01's Avatar
'08 GL 320 CDI
Just replace the engine on a regular basis.
Old Aug 23, 2021 | 03:47 PM
X166 GL550
Sludge can be caused by no oil changes, overheating, mixing synthetic and conventional, excessive idling and lots of short trips, which prevent the oil from fully cycling, environmental contaminants in the oil (like dirt and debris), condensation, which can contaminate the oil with moisture, hot spots, which bake clumps and oil right onto the engine.
I knew about a owner that brought his GL450 for warranty because the car was overheating and the dealer found that he never changed the oil for more than 65K. According to the owner, nobody told him that the car needed oil change!
Old Aug 23, 2021 | 04:11 PM
DennisG01's Avatar
'08 GL 320 CDI
That's the way of the world, it seems. "Nobody told me"... "I didn't know"... "It's not my fault". I could start a page long rant on this and WHEN are we going to stop allowing this type of behavior and hold people responsible for their behaviors... but I won't... I'll limit it to just a sentence or two
Old Aug 24, 2021 | 04:05 PM
lkchris's Avatar
'10 CL550, '12 GL550
Baloney … the dashboard put up service required messages
Old Aug 24, 2021 | 04:41 PM
X166 GL550
