Gl 450 A/c pressures
This is what i read through the scanner
but this should not affect my temps? Scanner also said pannel was ok! Rcv valve? This unit does not help a txv valve?where can I get a book on the whole system layout? thank you!
You need to replace the dryer as well, I chose behr 2518350047. Both dryer and compressor are the original manufactures for Mercedes.
OP: 100 on high side is way low, and 65 on low side is way high. That could be an indication of a failed compressor or control valve IF those readings were taken with the compressor engaged.
Make sure you have compressor engagement before you go and replace it. Ensure there are no trouble codes for air temperature sensors or blowers and pressure sensor.
If the compressor is not running, shouldn't the pressures be identical?
