Is STAR required to program AIRmatic?
The car is STILL riding low low low low
it seems like the only thing left to change are the sensors, the back bags, and the reservoir itself.
After changing the Valve Body (I think that is the name) I was told that something needs to be reprogrammed with the STAR and that is why it is riding low.
Is it true something needs to be programmed by STAR?
you might want to putter around a Parking lot if she’s scraping and see if she comes up - if not the fault lies elsewhere. Sensors or rear bags - reservoir I’ve never heard of being an issue unless it’s been punctured.
Dont you have DAs though? Raise/calibrate it up manually then And see if the ride level stays…
it’s under chassis - airmatic - actuations iirc?
its been so long since I ever had to touch my das wrt airmatic stuff…
does anybody have the part number for the level sensors? Maybe I’ll just change those to see if that’s the issue
he tells me that the heat from the motor messed up the colors on some of the tubes and he guessed on the last 2.
if all the tubes aren't on right would that keep it from lifting?
does anybody have some type of video or diagram showing how to install the valve block?
It shouldn't be too hard to figure out which tube goes where. Three go to the back, one for each spring and one for the reservoir. One goes to each front spring, and one (the biggest) goes to the pump.
how do you fill the strut individually? and what does checked at their full range of travel mean?
what is a leak down test?
what is the pump level valve? that was recently changed also. I'm just trying to figure out what went wrong here.
i took it back in and they changed the pump level sensor and when they gave it back to me it was all flat. I told them it won’t raise even with the button and they changed the valve block. Still won’t raise. So now 2 front struts, a pump, a valve block, and a pump level sensor later the car still won’t raise!
the must be something I’m missing. The original code was 5503: recovery time of filing central reservoir is too long.
how many lines come off the reservoir? Where do they go?
i used the button on the drivers door to open the liftgate. It only opened halfway. I pulled the button again and it went all the way up.
it’s been working good so far.
if it acts up again I’ll change the pump and reassess.
thanks to all who helped
